Introduzione
To replace the battery you will need a replacement. Once you have the battery, following this guide will lead you to a fully functioning device.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Anti-Static Wrist Strap$7.95
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Altre 3 persone hanno completato questa guida.
Un commento
where can i purchase a battery, i have googled and come up with nothing.
