Salta al contenuto principale
Leapfrog LeapPad 3 Battery Replacement
Cosa ti serve
  1. Leapfrog LeapPad 3 Battery Replacement, Battery: passo 1, immagine 1 di 3 Leapfrog LeapPad 3 Battery Replacement, Battery: passo 1, immagine 2 di 3 Leapfrog LeapPad 3 Battery Replacement, Battery: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Battery Replacement: passo 2, immagine 1 di 3 Leapfrog LeapPad 3 Battery Replacement: passo 2, immagine 2 di 3 Leapfrog LeapPad 3 Battery Replacement: passo 2, immagine 3 di 3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Battery Replacement: passo 3, immagine 1 di 2 Leapfrog LeapPad 3 Battery Replacement: passo 3, immagine 2 di 2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
Conclusione
Altre 3 persone hanno completato questa guida.
Matt Irvine
Membro da: 02/04/16
952 Reputazione
6 Guide realizzate
USF Tampa, Team 16-2, Blackwell Winter 2016 Membro di USF Tampa, Team 16-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G2
3 Membri
12 Guide realizzate
Un commento
where can i purchase a battery, i have googled and come up with nothing.
martinez2503 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,282
