Salta al contenuto principale
LeapFrog Scribble and Write Motherboard Replacement
Cosa ti serve
  1. LeapFrog Scribble and Write Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
  2. LeapFrog Scribble and Write Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the back battery cover and all of the batteries.
  3. LeapFrog Scribble and Write Motherboard Replacement: passo 3, immagine 1 di 1
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
  4. LeapFrog Scribble and Write Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the back cover from your toy.
  5. LeapFrog Scribble and Write Motherboard Replacement: passo 5, immagine 1 di 1
    • Using a Phillips screwdriver, remove the four screws from the motherboard.
  6. LeapFrog Scribble and Write Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the keyboard ribbon from the motherboard.
  7. LeapFrog Scribble and Write Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the speaker wires from the motherboard with your soldering iron.
  8. LeapFrog Scribble and Write Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the battery wires from the motherboard with the soldering iron.
  9. LeapFrog Scribble and Write Motherboard Replacement: passo 9, immagine 1 di 1
    • Remove the switch wires from the motherboard with the soldering iron.
  10. LeapFrog Scribble and Write Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove the pen wires from the motherboard with the soldering iron.
  11. LeapFrog Scribble and Write Motherboard Replacement: passo 11, immagine 1 di 1
    • Remove the volume control switch from the motherboard with the soldering iron.
Conclusione
Shang
Membro da: 02/10/16
328 Reputazione
3 Guide realizzate
USF Tampa, Team 1-5, Nance Spring 2016 Membro di USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 668
