Salta al contenuto principale
LeapFrog Scribble and Write Eraser Slider Cleaning
Cosa ti serve
  1. LeapFrog Scribble and Write Eraser Slider Cleaning, Eraser Slider: passo 1, immagine 1 di 1
    • Turn the toy over so the back is facing upward.
  2. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 2, immagine 1 di 1
    • Using a Phillips #0 screwdriver, carefully remove all 9 screws.
    • Set aside screws in a safe place for later reassembly.
  3. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 3, immagine 1 di 1
    • Remove the back of the toy by carefully lifting it up.
  4. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 4, immagine 1 di 2 LeapFrog Scribble and Write Eraser Slider Cleaning: passo 4, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the two screws that secure the screen to the motherboard.
    • Set aside screws in a safe place.
    • Gently remove the motherboard to expose the display screen and eraser slider.
  5. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 5, immagine 1 di 1
    • Carefully remove the display screen, leaving the eraser slider attached.
  6. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 6, immagine 1 di 2 LeapFrog Scribble and Write Eraser Slider Cleaning: passo 6, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the eraser slider.
  7. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 7, immagine 1 di 1
    • Lastly, use a soft towel to clean the eraser slider, removing any debris.
    • When all previous seven steps are completed, go backwards and re-screw and put together your The LeapFrog Scribble and Write
Conclusione
Shang
Membro da: 02/10/16
328 Reputazione
3 Guide realizzate
USF Tampa, Team 1-5, Nance Spring 2016 Membro di USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 948
