Salta al contenuto principale
LeapFrog LeapTV Controller Button Replacement
Cosa ti serve
  1. LeapFrog LeapTV Controller Button Replacement, Battery: passo 1, immagine 1 di 1
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Button Replacement: passo 2, immagine 1 di 1
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Button Replacement: passo 3, immagine 1 di 1
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Button Replacement, Buttons: passo 4, immagine 1 di 1
    • Use the screwdriver to remove the eight 8.7mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Button Replacement: passo 5, immagine 1 di 1
    • Slightly lift up on the back cover until the handle covers are free to rotate.
  6. LeapFrog LeapTV Controller Button Replacement: passo 6, immagine 1 di 1
    • Slide the the side of the handle facing you to the left to reveal the "A" and "B" button circuit board.
  7. LeapFrog LeapTV Controller Button Replacement: passo 7, immagine 1 di 1
    • Use the screwdriver to remove the three 8.5mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Button Replacement: passo 8, immagine 1 di 1
    • Lift up on the circuit board and move it to the side.
    • Be careful to not cause excess stress to the connecting wires when handling the circuit board. Excess stress can cause solder points to break.
  9. LeapFrog LeapTV Controller Button Replacement: passo 9, immagine 1 di 1
    • Use the plastic opening tool to release the buttons from the controller casing.
  10. LeapFrog LeapTV Controller Button Replacement: passo 10, immagine 1 di 1
    • Remove the "A" and "B" buttons by pulling up on one of the buttons.
  11. LeapFrog LeapTV Controller Button Replacement: passo 11, immagine 1 di 1
    • Buttons are now removed.
Conclusione
IUPUI, Team S4-G2, Baechle Spring 2017 Membro di IUPUI, Team S4-G2, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 359
