Salta al contenuto principale
LeapFrog LeapPad Ultra Repair Screen Replacement
Cosa ti serve
  1. LeapFrog LeapPad Ultra Repair Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 2, immagine 1 di 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 4, immagine 1 di 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 5, immagine 1 di 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 6, immagine 1 di 2 LeapFrog LeapPad Ultra Repair Screen Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Screen Replacement, Motherboard: passo 7, immagine 1 di 3 LeapFrog LeapPad Ultra Repair Screen Replacement, Motherboard: passo 7, immagine 2 di 3 LeapFrog LeapPad Ultra Repair Screen Replacement, Motherboard: passo 7, immagine 3 di 3
    • Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
  8. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 8, immagine 1 di 1
    • Unscrew the five screws holding the motherboard into the housing.
  9. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 9, immagine 1 di 3 LeapFrog LeapPad Ultra Repair Screen Replacement: passo 9, immagine 2 di 3 LeapFrog LeapPad Ultra Repair Screen Replacement: passo 9, immagine 3 di 3
    • Lift the motherboard up exposing the fourth and final wire. Once you lift up the motherboard you will need to pull down on the wire to disconnect.
  10. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 10, immagine 1 di 1
    • Remove and replace motherboard.
  11. LeapFrog LeapPad Ultra Repair Screen Replacement, Screen: passo 11, immagine 1 di 2 LeapFrog LeapPad Ultra Repair Screen Replacement, Screen: passo 11, immagine 2 di 2
    • Remove the side grips simply pulling them both vertically exposing eight screws.
  12. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 12, immagine 1 di 1
    • Using the screwdriver with the PH1 bit, unscrew all nine of the exposed screws holding the plastic base down and remove the base.
  13. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 13, immagine 1 di 1
    • Using the screwdriver with the PH00 bit, unscrew the twelve screws holding the screen casing down.
  14. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 14, immagine 1 di 1
    • Separate the screen from the casing and circuit board.
  15. LeapFrog LeapPad Ultra Repair Screen Replacement: passo 15, immagine 1 di 1
    • Replace screen.
Conclusione
Altre 10 persone hanno completato questa guida.
USF Tampa, Team 4-99, Meier Fall 2015 Membro di USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 Membri
10 Guide realizzate
8 Commenti
I need a source for the LCD screen. Anyone have a connection?
rhilscher - Replica
Where would i purchase the new screen?
gaildavies282 - Replica
You cannot get the screens. I had to get one from a parted device. Best you could try for is finding one the correct size with the connector in the proper place that is 50 pin.
crhouk - Replica
I bought mine on eBay for 15.00.
Joel Marcarelli - Replica
Could you send the link to where you bought yours
Michelle Popoff -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 43
Tutti i Tempi: 15,395
