Introduzione
If you suspect an issue with your LeapPad Platinum's motherboard, you can follow this guide to replace it. Be sure to turn off your device prior to opening it up and removing parts!
Cosa ti serve
Locate the white ribbon cable connected to the motherboard.
Disconnect the cable by flipping up the metal tab on the connector and sliding the cable out.
Rotate your device 180 degrees so the the motherboard is on your right-hand side and gently lift the front edge of the motherboard to reveal an orange sheet of plastic.
Disconnect the orange sheet from the motherboard by lifting the metal tab on the connector (as you did for the cables in steps 1 and 2), and lift the motherboard completely out of the device.
