Salta al contenuto principale
LeapFrog LeapPad Platinum Battery Replacement
Cosa ti serve
  1. LeapFrog LeapPad Platinum Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place your tablet on a flat surface with the screen facing down.
  2. LeapFrog LeapPad Platinum Battery Replacement: passo 2, immagine 1 di 2 LeapFrog LeapPad Platinum Battery Replacement: passo 2, immagine 2 di 2
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Battery Replacement: passo 3, immagine 1 di 2 LeapFrog LeapPad Platinum Battery Replacement: passo 3, immagine 2 di 2
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Battery Replacement: passo 4, immagine 1 di 1
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Battery Replacement: passo 5, immagine 1 di 3 LeapFrog LeapPad Platinum Battery Replacement: passo 5, immagine 2 di 3 LeapFrog LeapPad Platinum Battery Replacement: passo 5, immagine 3 di 3
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
  6. LeapFrog LeapPad Platinum Battery Replacement: passo 6, immagine 1 di 1
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
Conclusione
Altre 2 persone hanno completato questa guida.
UW Tacoma, Team 1-5, Rose Winter 2016 Membro di UW Tacoma, Team 1-5, Rose Winter 2016
UWT-ROSE-W16S1G5
4 Membri
8 Guide realizzate
3 Commenti
Any advice on how to fix a stylus go a leap pad platinum? The top is damaged- can I use any stylus or another platinum stylus it just buy a mesh tip? I can’t seem to find any too buy???
Ann-Mariah Thurber - Replica
The stylus is PART of the LeapPad so, there's no way to replace it.
Luke Sawczak -
This was very helpful thank you 😁
Luke Sawczak - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 7,964
