Salta al contenuto principale
Leader Impression i10A-LE Speakers Replacement
Cosa ti serve
  1. Leader Impression i10A-LE Speakers  Replacement, Speakers: passo 1, immagine 1 di 1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Speakers  Replacement: passo 2, immagine 1 di 3 Leader Impression i10A-LE Speakers  Replacement: passo 2, immagine 2 di 3 Leader Impression i10A-LE Speakers  Replacement: passo 2, immagine 3 di 3
    • Start by prying the back off by using plastic opening tools
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Speakers  Replacement: passo 3, immagine 1 di 3 Leader Impression i10A-LE Speakers  Replacement: passo 3, immagine 2 di 3 Leader Impression i10A-LE Speakers  Replacement: passo 3, immagine 3 di 3
    • Use the spudger to pry both of the speakers from the tablet.
    • Follow both sets of speaker wires to the motherboard where they are connected.
    • Desolder the wire connections from the motherboard.
Conclusione
jcg
Membro da: 11/14/16
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 126
