Salta al contenuto principale
Leader Impression i10A-LE Microphone Replacement
Cosa ti serve
  1. Leader Impression i10A-LE Microphone Replacement, Microphone: passo 1, immagine 1 di 1
    • Orient your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Microphone Replacement: passo 2, immagine 1 di 3 Leader Impression i10A-LE Microphone Replacement: passo 2, immagine 2 di 3 Leader Impression i10A-LE Microphone Replacement: passo 2, immagine 3 di 3
    • Pry the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Microphone Replacement: passo 3, immagine 1 di 2 Leader Impression i10A-LE Microphone Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the positive and negative battery leads.
    • Remove the microphone from plastic housing with the tweezers.
    • Desolder the positive (red) and negative (black) power leads.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 113
