Salta al contenuto principale
Leader Impression i10A-LE Front Facing Camera Replacement
Cosa ti serve
  1. Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: passo 1, immagine 1 di 2 Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: passo 1, immagine 2 di 2
    • Start by prying the back off by using plastic opening tools.
    • Slide the flat end of the plastic tools into the seam device.
    • Using another plastic tool, slowly pry along the seam until the back pops off.
  2. Leader Impression i10A-LE Front Facing Camera Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Reminder to disconnect the battery.
    • Locate the Camera in the top left corner of the Leader Impression.
    • Using the tweezers, remove the bottom of the camera from the motherboard.
    • The top of the camera will detach as you pull upward.
  3. Leader Impression i10A-LE Front Facing Camera Replacement: passo 3, immagine 1 di 1
    • Remove the camera from it's slot.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 118
