Salta al contenuto principale
Leader Impression i10A-LE Battery Pack Replacement
Cosa ti serve
  1. Leader Impression i10A-LE Battery Pack Replacement, Battery Pack: passo 1, immagine 1 di 1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Battery Pack Replacement: passo 2, immagine 1 di 3 Leader Impression i10A-LE Battery Pack Replacement: passo 2, immagine 2 di 3 Leader Impression i10A-LE Battery Pack Replacement: passo 2, immagine 3 di 3
    • Use the plastic prying tools to crack open the back of the device.
    • Once cracked, use more plastic prying tools to fully remove the back panel. A popping noise will occur when each clip is opened.
    • Remove the back panel and set aside.
  3. Leader Impression i10A-LE Battery Pack Replacement: passo 3, immagine 1 di 2 Leader Impression i10A-LE Battery Pack Replacement: passo 3, immagine 2 di 2
    • The battery pack is glued to the device.
    • Use a spudger to pry the battery pack from the glue.
    • Desolder the positive (red) and negative (black) power leads.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 571
