Introduzione
If the battery is too low for the device to turn on, replacing the battery may be necessary. If the device does not turn on after charging, the battery is most likely completely dead. When a battery is completely discharged, it oftentimes cannot be recharged. In this case, the battery is dead and needs to be replaced. No special skills or tools will be needed in order to complete this guide.
Cosa ti serve
Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
Altre 3 persone hanno completato questa guida.
5 Commenti
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
