Salta al contenuto principale
Le Pan II Screen Replacement
Cosa ti serve
  1. Le Pan II Screen Replacement, Screen: passo 1, immagine 1 di 2 Le Pan II Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Screen Replacement: passo 2, immagine 1 di 2 Le Pan II Screen Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Screen Replacement: passo 3, immagine 1 di 2 Le Pan II Screen Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Screen Replacement: passo 4, immagine 1 di 1
    • Remove grey metal backing from screen.
  5. Le Pan II Screen Replacement: passo 5, immagine 1 di 1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Screen Replacement: passo 6, immagine 1 di 1
    • Lift and carefully remove the LCD display from the front cover.
Conclusione
Kelly Moniz
Membro da: 10/20/16
513 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 6-3, Martin Fall 2016 Membro di UMass Dartmouth, Team 6-3, Martin Fall 2016
UMASSD-MARTIN-F16S6G3
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 300
