Salta al contenuto principale
Lasko Box Fan Back Wire Repair
Cosa ti serve
  1. Lasko Box Fan Back Wire Repair, Lasko Box Fan Back Wire Repair: passo 1, immagine 1 di 3 Lasko Box Fan Back Wire Repair, Lasko Box Fan Back Wire Repair: passo 1, immagine 2 di 3 Lasko Box Fan Back Wire Repair, Lasko Box Fan Back Wire Repair: passo 1, immagine 3 di 3
    • Make sure the fan is unplugged.
    • Unscrew the 6 screws on the front of the fan.
    • Remove the face plate.
    • Flip the fan and repeat for the 6 screws on the back. They are in the same position as the front.
  2. Lasko Box Fan Back Wire Repair: passo 2, immagine 1 di 2 Lasko Box Fan Back Wire Repair: passo 2, immagine 2 di 2
    • Unscrew the screws attaching the motor/blades to the frame.
    • Unscrew the screws attaching the plastic frame to the motor.
    • The blades cannot be removed from the motor.
  3. Lasko Box Fan Back Wire Repair: passo 3, immagine 1 di 2 Lasko Box Fan Back Wire Repair: passo 3, immagine 2 di 2
    • Strip the wires using wire strippers.
  4. Lasko Box Fan Back Wire Repair: passo 4, immagine 1 di 1
    • Twist the ends of the wire together
    • Place wires in soldering kit arms.
  5. Lasko Box Fan Back Wire Repair: passo 5, immagine 1 di 2 Lasko Box Fan Back Wire Repair: passo 5, immagine 2 di 2
    • Plug in the soldering iron.
    • When the soldering iron is hot, solder the wires together.
    • Place the tip of the soldering iron on the wires directly.
    • Place the solder on the wire.
    • Remove the solder and soldering iron from the wire
    • Repeat this step with the second wire.
    • Soldering irons are very hot!
  6. Lasko Box Fan Back Wire Repair: passo 6, immagine 1 di 3 Lasko Box Fan Back Wire Repair: passo 6, immagine 2 di 3 Lasko Box Fan Back Wire Repair: passo 6, immagine 3 di 3
    • Use electrical tape to insulate the wires.
    • Wrap the tape around each wire.
    • Wrap tape around the outside of all of the wires.
    • Make sure to completely cover any exposed wire.
  7. Lasko Box Fan Back Wire Repair: passo 7, immagine 1 di 2 Lasko Box Fan Back Wire Repair: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Clean out the dust from the blades and motor using tweezers.
  8. Lasko Box Fan Back Wire Repair: passo 8, immagine 1 di 3 Lasko Box Fan Back Wire Repair: passo 8, immagine 2 di 3 Lasko Box Fan Back Wire Repair: passo 8, immagine 3 di 3
    • Tape wires along the frame to prevent further damage.
    • Put the face plates back on and enjoy!
Conclusione
Altre 3 persone hanno completato questa guida.
Zach Emard
Membro da: 09/29/15
227 Reputazione
1 Guida realizzata
Cal Poly, Team 14-1, Green Fall 2015 Membro di Cal Poly, Team 14-1, Green Fall 2015
CPSU-GREEN-F15S14G1
4 Membri
4 Guide realizzate
8Commenti sulla guida
Any tips for replacing the "Blue Plug" fuse after it's mysteriously blown in a Lasko box fan?
https://www.amazon.com/fused-safety-Lask...
I could hillbilly wire up a new plug to minimize the wire work, but don't want to start a fire either.
Zac Appleton - Replica
I would also like to know how to replace the plug end after the non-replaceable fuse inside the plug is blown.
Gung Ho - Replica
I don't know bout you but I was able to “pop" my fan blades right off of motor. Now I'm just going to replace plug end and see if it'll work since fixing wires didn't help.
(Yep found fuse was blown. Why would they make the fuse non replaceable when they eventually blow? Wonder how many fans people have thrown out all because of a blown fuse??
Steff Lusher - Replica
That's exactly why it is non replaceable..
Throw it away and buy a NEW one.
2nd Son Home Services -
Not one thing worked
zakkerycastine876 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 73
Tutti i Tempi: 23,853
