Salta al contenuto principale
Large Animal Water Nipple Replacement
Cosa ti serve
  1. Large Animal Water Nipple Replacement, Large Animal Water Nipple: passo 1, immagine 1 di 1
    • Empty the container of all water.
  2. Large Animal Water Nipple Replacement: passo 2, immagine 1 di 1
    • With an adjustable wrench, unscrew the nut on the inside located near the base on the backside of the nipple.
  3. Large Animal Water Nipple Replacement: passo 3, immagine 1 di 1
    • Pull the mechanism out from the front.
  4. Large Animal Water Nipple Replacement: passo 4, immagine 1 di 1
    • Ensure there is no damage to the hole that needs to be patched.
    • Cracks or fractures are easily made due to sun damage or forcing the mechanism in or out.
  5. Large Animal Water Nipple Replacement: passo 5, immagine 1 di 1
    • Use Teflon tape to line the threads of the new nipple.
  6. Large Animal Water Nipple Replacement: passo 6, immagine 1 di 2 Large Animal Water Nipple Replacement: passo 6, immagine 2 di 2
    • Place the new nipple in the hole with the peg on top.
  7. Large Animal Water Nipple Replacement: passo 7, immagine 1 di 1
    • Fill the container slightly to ensure that there are no leaks. Tighten the washer or pull out to see if a crack has formed while replacing.
    • Tighten the washer to see if that is the source of the leak. If not, pull out to see if a crack has formed while replacing.
    • This is a leak in the seal.
  8. Large Animal Water Nipple Replacement: passo 8, immagine 1 di 1
    • If there is a leak try placing some more Teflon tape. If this does not fix the issue continue reading this step. If there is no longer a leak, move on.
    • Leaking from cracks are easily filled with caulking if the container is small. This would only be a temporary fix on a larger container. Due to the weight of the water, the barrel or bucket would need to be replaced.
  9. Large Animal Water Nipple Replacement: passo 9, immagine 1 di 1
    • Place and thread the nut on the inside of the container on the backside of the nipple.
  10. Large Animal Water Nipple Replacement: passo 10, immagine 1 di 1
    • Finally, place the container in the designated place and fill completely.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 203
