Salta al contenuto principale
Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement
Cosa ti serve
  1. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement, Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone: passo 1, immagine 1 di 2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement, Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone: passo 1, immagine 2 di 2
    • Switch off the grinder's breaker box before performing any maintenance on the machine.
  2. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 2, immagine 1 di 2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 2, immagine 2 di 2
    • Lift the yellow guard up to unlock the grindstone access panel.
  3. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 3, immagine 1 di 2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 3, immagine 2 di 2
    • Pull the access panel outward to expose the grindstone.
  4. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 4, immagine 1 di 2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 4, immagine 2 di 2
    • Remove the twelve bolts securing the grindstone using a ratchet with a 5/16 Hex bit.
  5. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 5, immagine 1 di 2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 5, immagine 2 di 2
    • Gently remove the steel hub from the grindstone spindle.
  6. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 6, immagine 1 di 2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 6, immagine 2 di 2
    • Carefully remove the grindstone itself from the spindle, making sure to support it from the top and inner ring.
    • Mind your fingers! The grindstone is quite heavy and can cause injury if it is mishandled or dropped.
  7. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 7, immagine 1 di 2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 7, immagine 2 di 2
    • Softly sand the hub with 600-grit sandpaper or a wire brush to remove any surface rust.
  8. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: passo 8, immagine 1 di 1
    • Although not mandatory, now would be a good time to scrape out any debris that has built up on the inside of the guard.
Conclusione
To reassemble your device, follow these instructions in reverse order starting from step 6.
Altre 3 persone hanno completato questa guida.
Texas Tech, Team 22-3, Rauch Spring 2016 Membro di Texas Tech, Team 22-3, Rauch Spring 2016
TTU-RAUCH-S16S22G3
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 40
Tutti i Tempi: 864
