Introduzione
This guide shows how to remove and replace the SSD for the LG gram (14Z980-A.AAS7U1) laptop.
Cosa ti serve
Utilize a screwdriver to remove the fasteners that secure the back cover.
Remove the 8 rubber feet and screws.
Insert a pry tool or your fingers between the back cover. Gently run the tool along the edges to release any clips or latches.
Carefully locate the battery connector within the laptop and gently detach it from its port by applying pressure and pulling it straight out.
Utilize a Phillips screwdriver to unscrew the 2.8 mm-sized screw that secures the SSD onto the LG Gram's motherboard.
Carefully grip the SSD by its edges and gently pull it straight out.
