Salta al contenuto principale
Introduzione
In this guide you will be removing the back panel to access the motherboard. Once you have reached the motherboard you will remove the camera lens from the motherboard.
Parti
Nessuna parte specificata.
  1. Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire. Place the phone facedown on the table. Use your fingernail (or a small screw driver) to pull down the tab below the battery.
    • Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone facedown on the table.
    • Use your fingernail (or a small screw driver) to pull down the tab below the battery.
    • Lift the battery out.
  2. Locate the five rubber covers on the back panel of the phone. Use the metal probe to pop out each rubber cover to reveal the screws underneath.
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  4. Locate the six 2.5mm screws on the back panel of the phone. Use a #00 Phillips screwdriver to remove each 2.5mm screw.
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  5. Locate the seam around the edge of the phone. Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  6. Locate the ribbon attached to the lens of the camera. Place the plastic opening tool in between the logic board and ribbon.
    • Locate the ribbon attached to the lens of the camera.
    • Place the plastic opening tool in between the logic board and ribbon.
    • Lift up the plastic opening to detach the ribbon from the logic board.
  7. Place the plastic opening tool in between the lens and the logic board. Detach the lens from the logic board using the plastic opening tool by popping it out.
    • Place the plastic opening tool in between the lens and the logic board.
    • Detach the lens from the logic board using the plastic opening tool by popping it out.
    • Take the entire lens and ribbon off of the logic board.
Conclusione
Reed Williston
Membro da: 26/09/2012
34 Reputazione
7 Guide realizzate
Cal Poly, Team 16-55, Forte Fall 2012 Membro di Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 374
