Introduzione
If you have broken or scratched your screen you may want to replace it with a new one.
Cosa ti serve
Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
The battery should easily fall out after the top of the battery has been pulled out.
Unscrew the six 2.4mm Phillips #00 screws (three on the left and three on the right of the phone) to remove the inner back case.
Turn the motherboard over and carefully remove the keypad from the motherboard.
The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
After removing the motherboard and keyboard, unscrew eight 1.6mm Phillips #00 screws in the middle of the phone.
Once you have removed the LCD, the front case/screen will be left.
If necessary, you may remove the call/mute/hang up button.
