Introduzione
After removing the back case, the battery is the next obstacle. Removing the battery is the solution to a lot of problems because it essentially restarts the phone. It is the gateway into the rest of the phone. The battery is a simple obstacle to overcome.
Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
The battery should easily fall out after the top of the battery has been pulled out.
