Salta al contenuto principale
LG X Style Speaker Replacement
Cosa ti serve
  1. LG X Style Speaker  Replacement, Screen: passo 1, immagine 1 di 2 LG X Style Speaker  Replacement, Screen: passo 1, immagine 2 di 2
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  2. LG X Style Speaker  Replacement: passo 2, immagine 1 di 3 LG X Style Speaker  Replacement: passo 2, immagine 2 di 3 LG X Style Speaker  Replacement: passo 2, immagine 3 di 3
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  3. LG X Style Speaker  Replacement, Battery: passo 3, immagine 1 di 1
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  4. LG X Style Speaker  Replacement: passo 4, immagine 1 di 2 LG X Style Speaker  Replacement: passo 4, immagine 2 di 2
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  5. LG X Style Speaker  Replacement, Speaker: passo 5, immagine 1 di 3 LG X Style Speaker  Replacement, Speaker: passo 5, immagine 2 di 3 LG X Style Speaker  Replacement, Speaker: passo 5, immagine 3 di 3
    • Insert the plastic opening tool into slit around speaker box on mid shield frame.
    • Gently pop up the speaker housing.
    • If the adhesive film doesn’t remove itself with the speaker housing, use the plastic opening tool to remove film.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 423
