Introduzione
Use this guide to remove your damaged speaker from your phone.
Cosa ti serve
Power down the device and make sure that it is turned off.
Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
Gently twist tool clockwise until the back case pops open [this will create a small gap].
Slide the tool along the gap around the entire device.
Insert the plastic opening tool into slit around speaker box on mid shield frame.
Gently pop up the speaker housing.
If the adhesive film doesn’t remove itself with the speaker housing, use the plastic opening tool to remove film.
