Introduzione
This guide will show you how to replace the LCD screen on a LG X Power smartphone.
Cosa ti serve
Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
Pull the cameras out to remove them.
Carefully peal off the glued vibration motor by using the plastic opening tool.
Altre 16 persone hanno completato questa guida.
7 Commenti
If you are just replacing the screen, this is wrong. This would help if you are replacing with a “screen in frame”
What is the right way for just the screen?
Where’s the part where you actually remove the screen and add in the new one?
The last step seems to be prying off the ear speaker.
Could you please fix this guide when you get the chance? I might replace the screen on my LG Power X [K210]. Thanks.
Okay.... and? I got that far. How do I get the screen out?
What is the price of the screen?
