Salta al contenuto principale
LG X Power Charging Port Replacement
Cosa ti serve
  1. LG X Power Charging Port Replacement, LG X Power Disassembly: passo 1, immagine 1 di 2 LG X Power Charging Port Replacement, LG X Power Disassembly: passo 1, immagine 2 di 2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Charging Port Replacement: passo 2, immagine 1 di 2 LG X Power Charging Port Replacement: passo 2, immagine 2 di 2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Charging Port Replacement: passo 3, immagine 1 di 2 LG X Power Charging Port Replacement: passo 3, immagine 2 di 2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Charging Port Replacement, Charging Port: passo 4, immagine 1 di 3 LG X Power Charging Port Replacement, Charging Port: passo 4, immagine 2 di 3 LG X Power Charging Port Replacement, Charging Port: passo 4, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Charging Port Replacement: passo 5, immagine 1 di 1
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Charging Port Replacement: passo 6, immagine 1 di 1
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Charging Port Replacement: passo 7, immagine 1 di 1
    • Desolder the MicroUSB charging port from the motherboard.
    • If you need help soldering, follow this guide.
Conclusione
Altre 5 persone hanno completato questa guida.
Chad Sears
Membro da: 02/14/18
1.149 Reputazione
5 Guide realizzate
USF Tampa, Team S3-G6, Nance Spring 2018 Membro di USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Membri
12 Guide realizzate
Un commento
Where can i get the charging port part? There are so many different usb female ports.
Wayne Newell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 5,917
