Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will show how to replace the camera on a LG X Power smartphone.
  1. Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off. Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. Remove the twelve 2.5mm Phillips #0 screws from the back of the phone. Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click. With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard. Pull the cameras out to remove them.
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
Conclusione
Chad Sears
Membro da: 14/02/2018
947 Reputazione
5 Guide realizzate
USF Tampa, Team S3-G6, Nance Spring 2018 Membro di USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 381
