Salta al contenuto principale
LG Watch Urbane Motherboard Replacement
Cosa ti serve
  1. LG Watch Urbane Motherboard Replacement, Battery: passo 1, immagine 1 di 2 LG Watch Urbane Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Motherboard Replacement: passo 2, immagine 1 di 2 LG Watch Urbane Motherboard Replacement: passo 2, immagine 2 di 2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Motherboard Replacement: passo 3, immagine 1 di 3 LG Watch Urbane Motherboard Replacement: passo 3, immagine 2 di 3 LG Watch Urbane Motherboard Replacement: passo 3, immagine 3 di 3
    Magnetic Project Mat
    $19.95
    Compra
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Motherboard Replacement: passo 4, immagine 1 di 3 LG Watch Urbane Motherboard Replacement: passo 4, immagine 2 di 3 LG Watch Urbane Motherboard Replacement: passo 4, immagine 3 di 3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
  5. LG Watch Urbane Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • And now you have your motherboard
Conclusione
Altre 3 persone hanno completato questa guida.
Rey Diaz
Membro da: 08/31/15
699 Reputazione
2 Guide realizzate
USF Tampa, Team 1-4, Remmell Fall 2015 Membro di USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,171
