Introduzione
In order to replace your battery you are going to need the proper tools. There are screws that need to be unscrewed and components that need to be pried open carefully. The tools needed will be plastic opening tools, 000PH screwdriver and tweezers. With these prepared everything should be ready to start the replacement of the battery for the LG Watch Urbane.
Cosa ti serve
Push on the band in order to expose the pins
Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
Altre 18 persone hanno completato questa guida.
11 Commenti
"pried" not "pryed"
The reassembly requires gluing the back together. How do you get the glue?
