Salta al contenuto principale
LG Voyager Micro SD Replacement
Cosa ti serve
  1. LG Voyager Micro SD Replacement, Micro SD: passo 1, immagine 1 di 1
    • Turn the phone onto its side so the label micro SD is facing upside down.
    • Once on its side, lift the micro SD cover up and swivel it away from the opening.
  2. LG Voyager Micro SD Replacement: passo 2, immagine 1 di 2 LG Voyager Micro SD Replacement: passo 2, immagine 2 di 2
    • The Micro SD card will appear as a thin plastic piece sticking out of the phone
    • Gently push down on the card, you should hear a click, and then it will "spring" back at you.
    • The card should be sticking out of the phone slightly once this is done.
    • Remove the card from the slot
Conclusione
Michelle
Membro da: 04/10/12
20 Reputazione
2 Guide realizzate
Cal Poly, Team 17-26, Amido Spring 2012 Membro di Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 466
