1. Turn over the phone so the front screen is facing down and the back side is up.
    • Turn over the phone so the front screen is facing down and the back side is up.
    Aggiungi Commento
  2. Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
    • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
    Aggiungi Commento
    • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
    • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
    • Then press down on the bottom of the battery and it should snap into place
    Aggiungi Commento
Conclusione
Michelle
Membro da: 10/04/2012
17 Reputazione
3 Guide realizzate
Cal Poly, Team 17-26, Amido Spring 2012 Membro di Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 270
