Salta al contenuto principale
LG VX9800 Front Keypad Replacement
Cosa ti serve
  1. LG VX9800 Front Keypad Replacement, Front Keypad: passo 1, immagine 1 di 1
    • Remove the two triangular pads at the top of the two speakers.
    • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
  2. LG VX9800 Front Keypad Replacement: passo 2, immagine 1 di 1
    • Remove the two rubber cylinders from their shafts. These cover more screws.
    • This requires a little more effort, so you may need to "dig" them out.
  3. LG VX9800 Front Keypad Replacement: passo 3, immagine 1 di 1
    • Now remove the four screws.
    • The screws are small, so put them somewhere that you can easily keep track of them.
  4. LG VX9800 Front Keypad Replacement: passo 4, immagine 1 di 1
    • Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
    • You should hear popping or snapping noises as the faceplate is being removed.
  5. LG VX9800 Front Keypad Replacement: passo 5, immagine 1 di 2 LG VX9800 Front Keypad Replacement: passo 5, immagine 2 di 2
    • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
  6. LG VX9800 Front Keypad Replacement: passo 6, immagine 1 di 3 LG VX9800 Front Keypad Replacement: passo 6, immagine 2 di 3 LG VX9800 Front Keypad Replacement: passo 6, immagine 3 di 3
    • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
    • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
    • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  7. LG VX9800 Front Keypad Replacement: passo 7, immagine 1 di 1
    • The faceplate and keypad can now be completely removed from the phone.
Linea Traguardo
Aaron Rowley
Membro da: 01/21/10
33 Reputazione
2 Guide realizzate
Cal Poly, Team 16-32, Maness Winter 2010 Membro di Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,899
