Salta al contenuto principale
LG VX8700 LCD Screen Replacement
Cosa ti serve
  1. LG VX8700 LCD Screen Replacement, Battery: passo 1, immagine 1 di 2 LG VX8700 LCD Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG VX8700 LCD Screen Replacement: passo 2, immagine 1 di 2 LG VX8700 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG VX8700 LCD Screen Replacement, Front Bezel: passo 3, immagine 1 di 1
    • Turn your phone around and open the flip phone. The screen is now facing you.
    • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
    • Remove the two grey screw-covers.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG VX8700 LCD Screen Replacement: passo 4, immagine 1 di 2 LG VX8700 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Use the ejection tab at the top to remove the screen.
    • There is a gap between the case and the screen near the ear piece.
    • Insert the plastic opening tool in the gap and pry up the screen.
    • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG VX8700 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG VX8700 LCD Screen Replacement: passo 6, immagine 1 di 2 LG VX8700 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Turn your phone around. The battery side will be facing you.
    • Insert the plastic opening tool into the groove to remove the top cover of the phone.
    • Carefully open the cover.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG VX8700 LCD Screen Replacement, Ear Piece: passo 7, immagine 1 di 1
    • Locate the earpiece, which is the black component at the top with black and red wires.
    • Remove the component. Using a soldering iron, desolder the top ear piece.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG VX8700 LCD Screen Replacement: passo 8, immagine 1 di 2 LG VX8700 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Using the plastic opening tool, lift the earpiece to remove it from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  9. LG VX8700 LCD Screen Replacement, LCD Screen: passo 9, immagine 1 di 1
    • Using a soldering iron, desolder the wires connected to the LCD board.
    Chiedi a FixBot
    Aggiungi Commento
  10. LG VX8700 LCD Screen Replacement: passo 10, immagine 1 di 1
    • Using the plastic opening tool, carefully disconnect the ribbon connecting the two pieces.
    Chiedi a FixBot
    Aggiungi Commento
  11. LG VX8700 LCD Screen Replacement: passo 11, immagine 1 di 1
    • Remove the LCD screen.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 8-16, Maness Winter 2012 Membro di Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Membri
21 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 41
Tutti i Tempi: 2,080
