  1. Sliding the battery cover off and remove the phone's battery. (see LG VX8560 Battery Replacement steps 1-3 for help) Sliding the battery cover off and remove the phone's battery. (see LG VX8560 Battery Replacement steps 1-3 for help) Sliding the battery cover off and remove the phone's battery. (see LG VX8560 Battery Replacement steps 1-3 for help)
  2. Using your Phillips screwdriver unscrew all 4 screws along the edge of the phone Using your Phillips screwdriver unscrew all 4 screws along the edge of the phone
    • Using your Phillips screwdriver unscrew all 4 screws along the edge of the phone
  3. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  4. Using your plastic pry tool, slide the tool between the phone’s keypad cover and back cover. You should be able to see the motherboard.  Don’t separate the two covers. They should be held together  by a screw at the axis of the phone. You should be able to see the motherboard.  Don’t separate the two covers. They should be held together  by a screw at the axis of the phone.
    • Using your plastic pry tool, slide the tool between the phone’s keypad cover and back cover.
    • You should be able to see the motherboard. Don’t separate the two covers. They should be held together by a screw at the axis of the phone.
  5. Place the side keys so that they are aligned with the silver circles located on the side of the  motherboard. Place the side keys so that they are aligned with the silver circles located on the side of the  motherboard.
    • Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
Conclusione
Kevin
Membro da: 18/04/2013
7 Reputation
2 Guide realizzate
Cal Poly, Team 13-62, Johann Spring 2013 Membro di Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Membri
12 Guide realizzate
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 126
