Salta al contenuto principale
LG VX8560 Motherboard Cushion Replacement
Cosa ti serve
  1. LG VX8560 Motherboard Cushion Replacement, Motherboard cushion: passo 1, immagine 1 di 1
  2. LG VX8560 Motherboard Cushion Replacement: passo 2, immagine 1 di 2 LG VX8560 Motherboard Cushion Replacement: passo 2, immagine 2 di 2
    • Locate the cushions, which should be in the corners of the motherboard.
    • Gently but firmly remove the old cushions with a pair of tweezers.
    • Replace the cushions with new ones using tweezers.
    • Be sure the cushions do not move and fall out after replacement, as they are not secure in place.
Conclusione
To reassemble your device, follow the General Disassembly LG VX 8560 guide.
Jack Foley
Membro da: 04/25/13
37 Reputazione
3 Guide realizzate
Cal Poly, Team 13-62, Johann Spring 2013 Membro di Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 209
