Salta al contenuto principale
LG VX8560 Keypad Replacement
Cosa ti serve
  1. LG VX8560 Keypad Replacement, Keypad: passo 1, immagine 1 di 2 LG VX8560 Keypad Replacement, Keypad: passo 1, immagine 2 di 2
    • Remove the battery by sliding the battery cover off the phone.
    • Unscrew all 4 screws along the edge of the phone using the Philips #00 Screwdriver.
  2. LG VX8560 Keypad Replacement: passo 2, immagine 1 di 2 LG VX8560 Keypad Replacement: passo 2, immagine 2 di 2
    • Insert the iFixit Opening Tool between the phone’s keypad cover and the back cover, and gently pull apart.
    • Be careful with the motherboard; don’t let it detach.
  3. LG VX8560 Keypad Replacement: passo 3, immagine 1 di 1
    • Insert the new keypad into the cover frame and check the dimensions.
  4. LG VX8560 Keypad Replacement: passo 4, immagine 1 di 2 LG VX8560 Keypad Replacement: passo 4, immagine 2 di 2
    • Gently snap the cover frame back to the right position.
    • Replace the screws using the Phillips #00 Screwdriver.
    • Insert the battery and snap the back cover on.
Conclusione
The keypad is successfully replaced.
Jack Foley
Membro da: 04/25/13
37 Reputazione
3 Guide realizzate
Cal Poly, Team 13-62, Johann Spring 2013 Membro di Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 280
