Salta al contenuto principale
LG VX8550 Speaker Replacement
Cosa ti serve
  1. LG VX8550 Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery release up.
  2. LG VX8550 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Speaker Replacement, Case: passo 3, immagine 1 di 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Speaker Replacement: passo 5, immagine 1 di 1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Speaker Replacement: passo 6, immagine 1 di 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Speaker Replacement: passo 7, immagine 1 di 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Speaker Replacement, Speaker: passo 8, immagine 1 di 1
    • With the back casing removed the speaker is visible.
  9. LG VX8550 Speaker Replacement: passo 9, immagine 1 di 1
    • Lift up under top end of circuit board with the Spludger to access retaining clip.
  10. LG VX8550 Speaker Replacement: passo 10, immagine 1 di 1
    • Carefully pry up on retaining clip with the Spudger to release the speaker.
  11. LG VX8550 Speaker Replacement: passo 11, immagine 1 di 1
    • Carefully unplug speaker connector from circuit board with your fingers.
  12. LG VX8550 Speaker Replacement: passo 12, immagine 1 di 1
    • Remove the speaker by lifting up.
Conclusione
Nathan Jones
Membro da: 04/10/10
89 Reputazione
10 Guide realizzate
Cal Poly, Team 34-55, Forte Spring 2010 Membro di Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,021
