Salta al contenuto principale
Introduzione
Steps to replace the LG VX8550 speaker
  1. Slide the battery release up.
    • Slide the battery release up.
  2. Remove the battery by lifting away from the case.
    • Remove the battery by lifting away from the case.
  3. Remove the 2 screw covers next to the rear speaker with a Push Pin.
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. Remove the 4 cover screws with a Philips #00 screwdriver.
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  6. Use the iPod opening tool to pry off the back casing.
    • Use the iPod opening tool to pry off the back casing.
  7. Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  8. Separate the casing halves.
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  9. With the back casing removed the speaker is visible.
    • With the back casing removed the speaker is visible.
  10. Lift up under top end of circuit board with the Spludger to access retaining clip.
    • Lift up under top end of circuit board with the Spludger to access retaining clip.
  11. Carefully pry up on retaining clip with the Spudger to release the speaker.
    • Carefully pry up on retaining clip with the Spudger to release the speaker.
  12. Carefully unplug speaker connector from circuit board with your fingers.
    • Carefully unplug speaker connector from circuit board with your fingers.
  13. Remove the speaker by lifting up.
    • Remove the speaker by lifting up.
Conclusione
Nathan Jones
Membro da: 10/04/2010
83 Reputazione
10 Guide realizzate
Cal Poly, Team 34-55, Forte Spring 2010 Membro di Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Membri
20 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,915
