Salta al contenuto principale
LG VX8550 Slider Mechanism Replacement
Cosa ti serve
  1. LG VX8550 Slider Mechanism Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery release up.
  2. LG VX8550 Slider Mechanism Replacement: passo 2, immagine 1 di 1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Slider Mechanism Replacement, Case: passo 3, immagine 1 di 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Slider Mechanism Replacement: passo 4, immagine 1 di 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Slider Mechanism Replacement: passo 5, immagine 1 di 1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Slider Mechanism Replacement: passo 6, immagine 1 di 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Slider Mechanism Replacement: passo 7, immagine 1 di 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Slider Mechanism Replacement, Motherboard: passo 8, immagine 1 di 1
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Slider Mechanism Replacement: passo 9, immagine 1 di 1
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Slider Mechanism Replacement: passo 10, immagine 1 di 1
    • Remove the motherboard from the front casing by lifting straight up.
  11. LG VX8550 Slider Mechanism Replacement, Keypad Housing: passo 11, immagine 1 di 1
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. LG VX8550 Slider Mechanism Replacement: passo 12, immagine 1 di 1
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. LG VX8550 Slider Mechanism Replacement: passo 13, immagine 1 di 1
    • Lift the keypad housing away from the slider.
  14. LG VX8550 Slider Mechanism Replacement, Front Case: passo 14, immagine 1 di 1
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
  15. LG VX8550 Slider Mechanism Replacement: passo 15, immagine 1 di 1
    • Remove the 6 screws with a Phillips #00 Screwdriver.
  16. LG VX8550 Slider Mechanism Replacement: passo 16, immagine 1 di 1
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
  17. LG VX8550 Slider Mechanism Replacement: passo 17, immagine 1 di 1
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
  18. LG VX8550 Slider Mechanism Replacement: passo 18, immagine 1 di 1
    • Slide ribbon cable through the slider mechanism.
  19. LG VX8550 Slider Mechanism Replacement: passo 19, immagine 1 di 1
    • Separate the two halves.
  20. LG VX8550 Slider Mechanism Replacement, Slider Mechanism: passo 20, immagine 1 di 1
    • With the slider mechanism separated from the screen casing the 8 screws securing the slider mechanism are visible.
    • Remove the 8 screws.
  21. LG VX8550 Slider Mechanism Replacement: passo 21, immagine 1 di 1
    • Remove slider mechanism. Now is a good time to clean slider mechanism if sticky.
Conclusione
Nathan Jones
Membro da: 04/10/10
89 Reputazione
10 Guide realizzate
Cal Poly, Team 34-55, Forte Spring 2010 Membro di Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,110
