Salta al contenuto principale
LG VX8300 Screen Housing Replacement
Cosa ti serve
  1. LG VX8300 Screen Housing Replacement, Disassembling LG VX8300 Body: passo 1, immagine 1 di 3 LG VX8300 Screen Housing Replacement, Disassembling LG VX8300 Body: passo 1, immagine 2 di 3 LG VX8300 Screen Housing Replacement, Disassembling LG VX8300 Body: passo 1, immagine 3 di 3
    • Power off the device by holding down the red button labeled PWR.
    • Be sure that the phone is powered off before touching the battery to avoid danger.
    • Remove the battery pack cover by pushing down on the solid lines at the top end of the cover. Slide the cover down while applying the pushing force at the top to remove the cover completely.
  2. LG VX8300 Screen Housing Replacement: passo 2, immagine 1 di 2 LG VX8300 Screen Housing Replacement: passo 2, immagine 2 di 2
    • Place your finger into the semicircle gap on top of the battery.
    • Apply force downward and out, so the battery pops out of the phone.
  3. LG VX8300 Screen Housing Replacement: passo 3, immagine 1 di 3 LG VX8300 Screen Housing Replacement: passo 3, immagine 2 di 3 LG VX8300 Screen Housing Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Locate the two rubber pads covering the screws at the top of the phone near the hinge.
    • Use tweezers to lift and remove the rubber pads.
  4. LG VX8300 Screen Housing Replacement: passo 4, immagine 1 di 2 LG VX8300 Screen Housing Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove all four 3mm screws from the back of the phone.
  5. LG VX8300 Screen Housing Replacement: passo 5, immagine 1 di 2 LG VX8300 Screen Housing Replacement: passo 5, immagine 2 di 2
    • Use your fingers to gently separate the front plate from the phone. You may need to slide a plastic opening tool along the crevice between the faces to separate it more easily.
    • Remove the casing after it has been detached. The logic board is now fully accessible.
    • Once the body case is removed, the volume and camera buttons move freely. Ensure all loose pieces remain accounted for.
  6. LG VX8300 Screen Housing Replacement, Screen Housing Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to gently lift the motherboard out of the case. The board is secured by six holes around the perimeter and will become free when pried from the supports.
  7. LG VX8300 Screen Housing Replacement: passo 7, immagine 1 di 2 LG VX8300 Screen Housing Replacement: passo 7, immagine 2 di 2
    • Remove the ribbon cable by lifting up the orange rectangle in the middle-top portion of the exposed device.
  8. LG VX8300 Screen Housing Replacement: passo 8, immagine 1 di 2 LG VX8300 Screen Housing Replacement: passo 8, immagine 2 di 2
    • Hold the phone securely in your left hand by placing your thumb on the hinge and wrapping your fingers around the back of the device.
    • Pinch the right flange near the flip hinge with the right hand and apply pressure.
    • Continue applying pressure until the two halves separate. Pull the bottom half towards you.
  9. LG VX8300 Screen Housing Replacement: passo 9, immagine 1 di 2 LG VX8300 Screen Housing Replacement: passo 9, immagine 2 di 2
    • Separate the keyboard from its housing.
    • Slide the ribbon cable out through the uppermost slot in the housing.
  10. LG VX8300 Screen Housing Replacement: passo 10, immagine 1 di 2 LG VX8300 Screen Housing Replacement: passo 10, immagine 2 di 2
    Compra
    • Remove the four rubber screw covers with tweezers located on the corners of the internal screen.
    • Remove all four 2 by 3 mm Phillips screws located under the rubber pads using a Phillips #00 screwdriver.
  11. LG VX8300 Screen Housing Replacement: passo 11, immagine 1 di 2 LG VX8300 Screen Housing Replacement: passo 11, immagine 2 di 2
    • Guide the spudger along the seam line of the phone screen to slowly separate the two pieces.
  12. LG VX8300 Screen Housing Replacement: passo 12, immagine 1 di 2 LG VX8300 Screen Housing Replacement: passo 12, immagine 2 di 2
    • Separate the external screen housing with your hands.
    • Replace the old screen housing with a new one and snap it together to complete the replacement.
Conclusione
Oscar
Membro da: 03/17/15
204 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 890
