Introduzione
Replacing your old or damaged battery with a new one will increase the life efficiency of the device.
Power off the device by holding down the power button.
Remove the battery cover by pushing down on the solid lines at the top of the cover. Then simply slide the cover down till it is completely removed.
Quasi finito!
After you finish replacing the battery make sure you put the battery cover back on and you will be all set.
Conclusione
