Salta al contenuto principale
LG VX7000 Internal LCD Screen Replacement
Cosa ti serve
  1. LG VX7000 Internal LCD Screen Replacement, Internal LCD Screen: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. LG VX7000 Internal LCD Screen Replacement: passo 2, immagine 1 di 1
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
  3. LG VX7000 Internal LCD Screen Replacement: passo 3, immagine 1 di 1
    • Unsnap gold plate from the secondary logic board.
    • Reposition the plate so that it is out of the way for face plate removal.
  4. LG VX7000 Internal LCD Screen Replacement: passo 4, immagine 1 di 1
    • Twist upper half of face plate in order to release it from the hinge.
    • Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
  5. LG VX7000 Internal LCD Screen Replacement: passo 5, immagine 1 di 1
    • Align new face plate in correct orientation in order to install.
Conclusione
Cal Poly, Team 18-75, Johann Spring 2010 Membro di Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,312
