Salta al contenuto principale
LG VX6100 Keypad Replacement
Cosa ti serve
  1. LG VX6100 Keypad Replacement, Back Cover: passo 1, immagine 1 di 1
    • Push down on the gray "PUSH" button on the back side of the phone.
    • Slide the back case downward. Then, lift and remove the case.
  2. LG VX6100 Keypad Replacement: passo 2, immagine 1 di 1
    • Lift up on the battery to remove it from the case.
  3. LG VX6100 Keypad Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a push-pin or tweezers to pry both of the tear-shaped screw covers out of the top of the phone.
  4. LG VX6100 Keypad Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to unscrew the six case screws from the back of the phone.
  5. LG VX6100 Keypad Replacement: passo 5, immagine 1 di 2 LG VX6100 Keypad Replacement: passo 5, immagine 2 di 2
    • Insert a plastic opener tool through the seam between the back case and the rest of the phone.
    • Slowly slide the tool along the seam. Lift up on the back case while you do this until the back case comes apart.
  6. LG VX6100 Keypad Replacement, Keypad: passo 6, immagine 1 di 1
    • Lift the bottom of the logic board out of the case.
    • Make sure not to lift the top of the logic board, since it is still connected to the backcase of the phone.
  7. LG VX6100 Keypad Replacement: passo 7, immagine 1 di 1
    • Gently lift up on any edge of the white keypad to remove it from the phone case.
Conclusione
Teal
Membro da: 04/17/12
1 Reputazione
2 Guide realizzate
Cal Poly, Team 12-39, Regan Spring 2012 Membro di Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 559
