Introduzione
These steps show how to remove the phone's front case. This allows access to many of the components located on the outer face of the phone.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Remove the four grey plugs using either tweezers or a push pin.
Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
Do this across the entire length of the seem until the case is no longer attached to the phone.
