Salta al contenuto principale
LG VX5600 Battery Replacement
  1. LG VX5600 Battery Replacement, Battery: passo 1, immagine 1 di 2 LG VX5600 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
    • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
  2. LG VX5600 Battery Replacement: passo 2, immagine 1 di 2 LG VX5600 Battery Replacement: passo 2, immagine 2 di 2
    • Insert your finger into the small indentation above the battery.
    • Push down on the battery and pull it away from the phone; it will pop out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 744
