Salta al contenuto principale
LG VX5500 Audio Port Replacement
Cosa ti serve
  1. LG VX5500 Audio Port Replacement, Battery: passo 1, immagine 1 di 3 LG VX5500 Audio Port Replacement, Battery: passo 1, immagine 2 di 3 LG VX5500 Audio Port Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Audio Port Replacement, Audio Port: passo 2, immagine 1 di 2 LG VX5500 Audio Port Replacement, Audio Port: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  3. LG VX5500 Audio Port Replacement: passo 3, immagine 1 di 3 LG VX5500 Audio Port Replacement: passo 3, immagine 2 di 3 LG VX5500 Audio Port Replacement: passo 3, immagine 3 di 3
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  4. LG VX5500 Audio Port Replacement: passo 4, immagine 1 di 2 LG VX5500 Audio Port Replacement: passo 4, immagine 2 di 2
    • Locate the audio port; this is what it should look like.
    • The audio port is mounted and connected at 6 points. Check the integrity of these connections.
    • If any of the connections are dislodged or the audio port is damaged, desolder the port and install a new one.
Conclusione
Altre 2 persone hanno completato questa guida.
Kurt Beske
Membro da: 05/07/12
70 Reputazione
1 Guida realizzata
Cal Poly, Team 7-33, Maness Spring 2012 Membro di Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 459
