Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
A guide on how to replace the logic board in the LG VX5400.
Parti
Nessuna parte specificata.
  1. Turn off the cell phone and turn it over on its back side
    • Turn off the cell phone and turn it over on its back side
  2. Hold the phone case in your palm and slide the back cover towards yourself using your thumb
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. Slide a tool or finger into the notch at the top of the battery  to carefully remove it. Slide a tool or finger into the notch at the top of the battery  to carefully remove it. Slide a tool or finger into the notch at the top of the battery  to carefully remove it.
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
    • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
  5. Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
    • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
  6. While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone. While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone.
    • While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone.
  7. Carefully slide out the keypad and remove the logic board. Then insert new the logic board. Carefully slide out the keypad and remove the logic board. Then insert new the logic board.
    • Carefully slide out the keypad and remove the logic board. Then insert new the logic board.
Conclusione
Altre 2 persone hanno completato questa guida.
Sourabh
Membro da: 15/04/2010
132 Reputazione
3 Guide realizzate
Cal Poly, Team 26-26, Regan Spring 2010 Membro di Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,390
