Salta al contenuto principale
LG VX5400 Keypad Replacement
Cosa ti serve
  1. LG VX5400 Keypad Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the cell phone and turn it over on its back side
  2. LG VX5400 Keypad Replacement: passo 2, immagine 1 di 1
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. LG VX5400 Keypad Replacement: passo 3, immagine 1 di 3 LG VX5400 Keypad Replacement: passo 3, immagine 2 di 3 LG VX5400 Keypad Replacement: passo 3, immagine 3 di 3
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. LG VX5400 Keypad Replacement, Keypad: passo 4, immagine 1 di 1
    • Remove the rubber stopper from the back top of the phone with the pointed end of a spudger.
  5. LG VX5400 Keypad Replacement: passo 5, immagine 1 di 1
    • Use the Phillip screw driver to remove the hidden screw, which is marked by the red square
  6. LG VX5400 Keypad Replacement: passo 6, immagine 1 di 1
    • Gently split open the front and back of the bottom casing of the phone with fingers.
  7. LG VX5400 Keypad Replacement: passo 7, immagine 1 di 1
    • Carefully pull the key pad from the phone through the opening.
  8. LG VX5400 Keypad Replacement: passo 8, immagine 1 di 1
    • See here for parts that have been removed.
Conclusione
Cal Poly, Team 26-26, Regan Spring 2010 Membro di Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Membri
11 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,418
