Salta al contenuto principale
LG VX5300 Keypad Replacement
Cosa ti serve
  1. LG VX5300 Keypad Replacement, Disassembling Back Cover: passo 1, immagine 1 di 3 LG VX5300 Keypad Replacement, Disassembling Back Cover: passo 1, immagine 2 di 3 LG VX5300 Keypad Replacement, Disassembling Back Cover: passo 1, immagine 3 di 3
    • Carefully slide battery cover off in a downward direction.
    • Using the plastic opening tool, remove the battery. Light force may be necessary.
  2. LG VX5300 Keypad Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
  3. LG VX5300 Keypad Replacement: passo 3, immagine 1 di 1
    • Using the plastic opening tool, carefully lift the back cover off.
  4. LG VX5300 Keypad Replacement, Keypad: passo 4, immagine 1 di 2 LG VX5300 Keypad Replacement, Keypad: passo 4, immagine 2 di 2
    • Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars.
    • Look to the following photo for the location of the two sensor bars.
    • Without disconnecting the orange wire, carefully flip the computer chip over and lay flat on the table, exposing the keypad.
  5. LG VX5300 Keypad Replacement: passo 5, immagine 1 di 2 LG VX5300 Keypad Replacement: passo 5, immagine 2 di 2
    • Carefully remove the keypad and replace with the new keypad.
    • If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
  6. LG VX5300 Keypad Replacement: passo 6, immagine 1 di 1
    • Carefully set the computer chip back in place.
  7. LG VX5300 Keypad Replacement: passo 7, immagine 1 di 2 LG VX5300 Keypad Replacement: passo 7, immagine 2 di 2
    • Place the back cover back on and secure it with the screws.
  8. LG VX5300 Keypad Replacement: passo 8, immagine 1 di 2 LG VX5300 Keypad Replacement: passo 8, immagine 2 di 2
    • Insert the battery.
    • Slide the back cover on the phone.
Linea Traguardo
Ashley
Membro da: 02/12/13
13 Reputazione
3 Guide realizzate
Ohio State, Team 1-1, Buehl Spring 2013 Membro di Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 575
