Salta al contenuto principale
LG VX5200 motherboard replacement
Cosa ti serve
  1. LG VX5200 motherboard replacement, Battery: passo 1, immagine 1 di 2 LG VX5200 motherboard replacement, Battery: passo 1, immagine 2 di 2
    • Turn the phone on its back.
  2. LG VX5200 motherboard replacement: passo 2, immagine 1 di 2 LG VX5200 motherboard replacement: passo 2, immagine 2 di 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 motherboard replacement: passo 3, immagine 1 di 2 LG VX5200 motherboard replacement: passo 3, immagine 2 di 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 motherboard replacement, LG VX5200 Rear Body Panel Disassembly: passo 4, immagine 1 di 1
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 motherboard replacement: passo 5, immagine 1 di 3 LG VX5200 motherboard replacement: passo 5, immagine 2 di 3 LG VX5200 motherboard replacement: passo 5, immagine 3 di 3
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 motherboard replacement: passo 6, immagine 1 di 3 LG VX5200 motherboard replacement: passo 6, immagine 2 di 3 LG VX5200 motherboard replacement: passo 6, immagine 3 di 3
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 motherboard replacement: passo 7, immagine 1 di 1
    • Check to see that your device looks like the attached photo.
  8. LG VX5200 motherboard replacement, main board: passo 8, immagine 1 di 3 LG VX5200 motherboard replacement, main board: passo 8, immagine 2 di 3 LG VX5200 motherboard replacement, main board: passo 8, immagine 3 di 3
    • Locate the tabs that hold the logic board in place.
    • Pull the outer frame of the phone outwards to release the board from the tabs.
  9. LG VX5200 motherboard replacement: passo 9, immagine 1 di 3 LG VX5200 motherboard replacement: passo 9, immagine 2 di 3 LG VX5200 motherboard replacement: passo 9, immagine 3 di 3
    • Locate the copper connection (orange-colored) on the back of the board.
    • Pry the connector free from the board with your fingernail.
  10. LG VX5200 motherboard replacement: passo 10, immagine 1 di 1
    • Check to see that your device looks like the image shown.
    • Note: The image is shown with the LCD screen removed. This is not necessary for logic board removal.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 4-13, Forte Winter 2010 Membro di Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,709
