Salta al contenuto principale
LG VX5200 Antenna Replacement
Cosa ti serve
  1. LG VX5200 Antenna Replacement, Battery: passo 1, immagine 1 di 2 LG VX5200 Antenna Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the phone on its back.
  2. LG VX5200 Antenna Replacement: passo 2, immagine 1 di 2 LG VX5200 Antenna Replacement: passo 2, immagine 2 di 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Antenna Replacement: passo 3, immagine 1 di 2 LG VX5200 Antenna Replacement: passo 3, immagine 2 di 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Antenna Replacement, LG VX5200 Rear Body Panel Disassembly: passo 4, immagine 1 di 1
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 Antenna Replacement: passo 5, immagine 1 di 3 LG VX5200 Antenna Replacement: passo 5, immagine 2 di 3 LG VX5200 Antenna Replacement: passo 5, immagine 3 di 3
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 Antenna Replacement: passo 6, immagine 1 di 3 LG VX5200 Antenna Replacement: passo 6, immagine 2 di 3 LG VX5200 Antenna Replacement: passo 6, immagine 3 di 3
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 Antenna Replacement: passo 7, immagine 1 di 1
    • Check to see that your device looks like the attached photo.
  8. LG VX5200 Antenna Replacement, Antenna: passo 8, immagine 1 di 1
    • Locate the screw and copper fixture that hold the antenna in place.
    • Remove the screw from the device using a Philips #00 screwdriver.
  9. LG VX5200 Antenna Replacement: passo 9, immagine 1 di 2 LG VX5200 Antenna Replacement: passo 9, immagine 2 di 2
    • Remove the copper fixture after it has been unscrewed.
  10. LG VX5200 Antenna Replacement: passo 10, immagine 1 di 2 LG VX5200 Antenna Replacement: passo 10, immagine 2 di 2
Conclusione
Cal Poly, Team 4-13, Forte Winter 2010 Membro di Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,439
